hey guys im having a huge problem with my 96Z ld9.  Just scanned my car for second time and still this is happening and dont know what to do.  when the is idle my timing shows  like -19  then when i WOT then start decreasing ..   Shouldnt be at 0 or positive something ?
how could i fix this.   i already took out the timing chain and put it back in .. checked the cam gears .. but dunno if the are in the right  position ..
Could some one please help me please
thanks
- or + is just perception
Actual ignition timing is usually #BTC
and BTC means Before Top Center
Top Center = 0°
so anything before zero can accurately be called -.
But most use a + number for it commonly.
besides that, if it was actually -19 or 19 ATC, the car wouldn't idle.
so either its a name game or inaccurate.
What device is telling you -19?
sig not found
is an obd 2 scanner that my mechanic use to detect  all the check engine codes  .. then when  he monitor the car in idle it gives you like the engine temperature, throttle , timing, knock activity and other things that i dont remember ..   and it shows as -19 not as +19  im asking for help on this because i dont know if this might be my main problem
here is my main problem ..   with i WOT  and the car gets to 3000rpms .. dunno if is because of timing or the knock acting weird but when i get to 3000rpms the car punch  me back  ..   like it would stop sucking fuel ..   i had and  SAFCII which i took out cus u guys told me that wont do me any good with my 96 ecu ..took it out .. but problem still persist..
dont know what to do ..   help please  thanks a lot
polloz24 wrote:is an obd 2 scanner that my mechanic use to detect  all the check engine codes  .. then when  he monitor the car in idle it gives you like the engine temperature, throttle , timing, knock activity and other things that i dont remember ..   and it shows as -19 not as +19  im asking for help on this because i dont know if this might be my main problem
Check wiring on the map sensor.
could the map sensor cause this if  its not working properly  ?
thanks
