which engine is considerd high rev and would be best suited for the cav
W41!
GMR has got nothing on this
W41, LD9, Ecotec.  All have been built for high RPM's by numerous Jbody members.
Green96 wrote:W41, LD9, Ecotec.  All have been built for high RPM's by numerous Jbody members.
true...but only the w41 was designed for "high rpm" from the factory
True.  Can't argue there.  All can be built for high RPM but that motor is just a beast the way it comes.
what determines if a motor can take high rpm's?  like, lets use ln2's...they could be de-stroked to go faster, but everyone says they aren't designed, and can't take higher rpm's...what decides that?
The LN2 is a pushrod motor, as opposed to an overhead cam setup.
Visit Fusion 9 Design for all your web design needs.
Dave De Stefano wrote:what determines if a motor can take high rpm's?  like, lets use ln2's...they could be de-stroked to go faster, but everyone says they aren't designed, and can't take higher rpm's...what decides that?
Mainly how well the bottom end is balance, cam profile, and valvetrain.
A unbalance bottom end can litterly shake the engine apart.
The cam profile determinds the "power band" on a N/A engine.  So without cams specifically made for 7k-8k rpms, you wont have the power and reving that high would just be pointless.
A valvetrain that isnt designed for high rpms will wear out quicker and break.  In a worse case senario it could cause this:
http://www.j-body.org/forums/read.php?f=46&i=384368&t=384368
Edited 1 time(s). Last edited Monday, March 30, 2009 11:35 PM
Tinkles
2003 Cavalier 1SV
Bagged and Blown
crap...thats rediculous.  thanks for the info there, guys!
