Ok so i got a 95 cavalier thats got a rod ready to fall out... I plan on buying a used 2.2 for it and i want to rebuild that motor over time then when its done put it in the cavy. I want to build it as much as possible while still having it streetable. I know for sure I want the head reworked, but i also want to build the internals of the motor, I would like to put out 225ish. I would prefer non turbo. so my list of questions is:
1) Where is a decent place to get bearings, rods, pistons, pushrods, a cam and the 1.6:1 rockers?
2) What am i going to need to do to tune the car so it runs properly?
3) Kind of vauge but just a guestimate on price for anyone who has something similar?
Im sorry if this was somewhere on here all the build threads I found were on oval and circle track cars... I still want a dd out of it just with a was that a quick cavalier feel to it. Any help would be very helpful. On a side note if anyone has a 94 or 95 2.2 for sale let me know the only one ive found is 450 for a motor with 160000.
Honda's are like tampons, Every PU$$Y has one!!!
my opinion is that you misspelled it, and meant LS2
info, 225 whp really isn't going to your idea of "street-able"
opinion: Drop a 3400 v6 in it, It's bolt in practically.
225 N/A would be a challenge without boost.
Swap to a 2.3 HO! Stock HO puts out 180hp. If that's not enough swap in a set of W41 cams makes 190hp stock. If that still isn't enough just add a 50shot to it and that should put you some where in the 215-245 range.
^^^Or just search in general
And work on your grammar! I could barely make sense of the beginning of your second paragraph!
Go beyond the "bolt-on".
Mike VanDiepen wrote:Im sorry if this was somewhere on here all the build threads I found were on oval and circle track cars...
That's because nobody on here has done it. Even 225 at the crank would hardly be "streetable", as it would be VERY difficult to reach that on pump gas...
I don't think you know what you're even asking for; maybe set your sights a little lower to get more experience first?
