If I bought a computer that was already reflashed from a 04 cavalier would it work in my 03 even if the vin numbers were different?
yes if its an auto and your putting it in a manual, the ses lite will be on for trans codes.
other than  that it will work fine
Built&Boosted moar
maybe, wouldnt the theft system activate since the vin changed? mine did when i put the flashed ecm in and i had to wait 10min and try again, then it worked.
12.33 @ 111.67 mph [Oct 2009]
327.6 WHP  333.6 WTQ [10.1 AFR]
You have to do a theft relearn. Make sure you have a wideband.
i have bonnetts old pcm, and im running it no problem, other than ses lite due to me have a manual trans
Built&Boosted moar
Also, you will run into trouble if you need to get the car OBD II emissions tested, since the vin on the computer does not match the vin of the car.
Its coming from a manual also and will the stock cobalt ss injectors work with the reflash.
last time i checked the sc reflash didnt have anything programmed for the trans tables.  im using injectors from a 3800s/c motor.  36 lb-hr and $75 for 6 on ebay.
"...and then God said let the 2.2's have potential.  Thats when hell broke loose..."
sorry it does have trans programming
Andrew Manczak wrote: will the stock cobalt ss injectors work with the reflash.
yes
^ You'll have injectors floating above your head though...find some bosch style injectors if you can.
Are you talking about the injectors being shorter?If so I bought a 02 fuel rail so they would sit  down all the way.
Is this the part number for the tmap sensor I will need 90423637.Also any one have a wiring diagram for how to wire it up and is this the sensor that bolts to the upper left of the intake manifold.
Admiral Jedi wrote:^ You'll have injectors floating above your head though...find some bosch style injectors if you can.
mine fit just fine
Built&Boosted moar
