first let me say, i have a boost controller and its set low so it doesn't create boost. i'm not tunned yet so i don't need boost.
i was driving to work and noticed my gauge read -7 at idle at when i get on the gas pedal. it goes passed 0 and up to 20, with no boost, i hear the turbo spool. but again no boost. i need help to know if my gauge is broke or if something is wrong? i don't believe its supposed to do that. any help would be appreciated, thanks.
How do you know that you are not making boost?  Are your running a mechanical or electric boost gauge?
Tinkles(KGM) wrote:How do you know that you are not making boost?  Are your running a mechanical or electric boost gauge?
because i dont feel the difference the boost is supposed to make, and i also had a friend of mine that had a boosted car drive mine and he also said it wasnt boosting... and its a electric digital gauge from glowshift
check your charge pipes, if its reading boost and you hear it and dont feel it, its gotta be going somewhere?
1st check to make sure that the wire(s) for the gauge are fine.  If they are, then you are making boost.  Healthy/new boost gauges do not randomly read 20psi of boost.  Without a proper tune you wont feel that much improvement.  You need to stop where you are and start educating yourself on turbocharging a vehicle before you go any farther.
Where is the boost gauge hooked up to? If its in the wrong spot it could be picking up pressure from something else.
DSMskyline wrote:Where is the boost gauge hooked up to? If its in the wrong spot it could be picking up pressure from something else.
its hooked to the port on the intake manifold, and a T fitting going to the bov
what spring is in your gate? a boost controller CANNOT turn the psi to 0.  It will only go as low as the spring in the gate.  Im gonna put money on you building boost.  Is your BOV going off?
Im going with masssssssssive boost leak, or just not understanding your setup. Like said, unless the spring in your wastegate is a 0 lb spring, which I have never heard of, you will build boost up to poundage of your spring. If all is well and there is not leak, then you would feel atleast SOME difference on a non tuned car. Also you should be hearing your BOV go off, unless it is not set up right aswell.
 But like Tink said, I would stop where you are and start reading. I would start by buying and reading this book.....
Maximum Boost
russ weisgarber wrote:what spring is in your gate? a boost controller CANNOT turn the psi to 0.  It will only go as low as the spring in the gate.  Im gonna put money on you building boost.  Is your BOV going off?
Its an internal wastegate, so I don't know off the top of my head. I would have to look when I get home.. and yes I hear the bov going off.
BOV = Blow.Off.Valve... it is put in place to relieve the pressure that is created in the pipes under load.
Therefore if it is venting then it is pressurizing.
-Chris-
-Sweetness-
-Turbocharged-
SweetnessGT wrote:BOV = Blow.Off.Valve... it is put in place to relieve the pressure that is created in the pipes under load.
-Chris-
I do know what bov means, but thanks anyways for thinking I'm stupid
sman wrote:SweetnessGT wrote:BOV = Blow.Off.Valve... it is put in place to relieve the pressure that is created in the pipes under load.
-Chris-
Thinking?  You are proving it on your own.  You need to stop, pick up a book(Corky Bell's "Maximum Boost" is a very good choice), and educate yourself.
The verdict:
You
ARE making boost.  20psi i would say.  It feels really weak, because it isnt properly tuned.  Also because it isnt properly tuned you are a few pulls away from blowing your engine.
Tinkles(KGM) wrote:sman wrote:SweetnessGT wrote:BOV = Blow.Off.Valve... it is put in place to relieve the pressure that is created in the pipes under load.
-Chris-
The verdict:
You ARE making boost.  20psi i would say.  It feels really weak, because it isnt properly tuned.  Also because it isnt properly tuned you are a few pulls away from blowing your engine.
There is no way its boosting 20 psi. I have a coupler on that will only hold 3psi then it will rip.. and its hasn't done that yet. And I know what the coupler will hold cuz I call rd fabs and was told. I have a new coupler coming. But until then it stays on.
sman wrote:Tinkles(KGM) wrote:sman wrote:SweetnessGT wrote:BOV = Blow.Off.Valve... it is put in place to relieve the pressure that is created in the pipes under load.
-Chris-
The verdict:
my mind is blown....im checking out of this thread.
Since you mentioned RD Fabs, I suggest you hand the car over to Ryan and let him take care of it and get it straightened out.
Ditch the boost controller, and run whatever your waste gate is set at. My guess is nothing more than 12psi since it's internal.
Then do some reading.
Then learn how to tune/get it tuned.
By then you'll be knowledgeable enough to know that is the blow off valve is "blowing off", then you are in fact making boost.  Whatever that psi number is... who know's because your electric boost gauge is probably broken or wired wrong.  Ditch that also and run a mechanical one.  Faster response, especially over glowshift ( I run glowshift, but I know the pitfalls of cheaper gauges)  A glowshift mechanical gauge and you will be sure of the boost you're getting.
After you have that setup properly tuned, then I would say It may be safe to use a boost controller.  More so if you learn how to use HP tuners (really not that hard if you take your time)
And for peet sake get a wide band (assuming you don't have one)
P.s. I've never heard of a coupler only handling 3psi... unless its paper or something.
I roll on steelies.  Work-in-progress daily-sleeper potential.
http://www.j-body.org/classifieds/engine/60493/
Eric Knight wrote:Ditch the boost controller, and run whatever your waste gate is set at. My guess is nothing more than 12psi since it's internal.
I really wish ppl would stop saying and thinking i dont know what im doing... i do, i bulit my own motor. i know if the bov is blowing off that its producing boost.. i just dont know how much cuz the gauge isnt really telling me... no the gauge is not wired wrong. and im going to efi alchemy for a tune in a few... i know how a turbo works... i dont need ppl telling me things i already know. im not stupid.. im actully about to hopefully have a job at a performace shop.. but im human, and every now and then i need some help/suggestions just like everyone else.... i but this post up to get help as to why my gauge is doing this. not for ppl to tell me bov= blow off valve.. and @!#$ i already know
and the coupler, ryan from rd fabs said the one i have was not meant of boost, just all motor. thats why it wont hold more then 3psi
but i do want to thank the ppl that are actually helping me.. like the one who asked where i hooked the gauge up to see if it might be reading pressure from somewhere else.. to yall, thank you.. thats the help im looking for
You havent done anything in this thread to make us think that you are not stupid.
Tinkles(KGM) wrote:You havent done anything in this thread to make us think that you are not stupid.
whatever man, ive answered all questions ppl have asked and using the right terms and describing what is happening.. and in the right way
But you turned your boost controller down so it wouldnt boost(which it doesnt work that way) and even thou your gauge is reading boost, you can hear the turbo spool, and the BOV go off you are convinced that you are not making boost.  Just because someone owned a boosted car doesnt mean that they know what they are doing, just look at Cobalt owners.
Even shifting early and keeping turbo under spool reads 10-20
Tinkles(KGM) wrote:But you turned your boost controller down so it wouldnt boost(which it doesnt work that way) and even thou your gauge is reading boost, you can hear the turbo spool, and the BOV go off you are convinced that you are not making boost.  Just because someone owned a boosted car doesnt mean that they know what they are doing, just look at Cobalt owners.
