i know, i know. The plastic needs to be cut of in most cases.
However would this work over our existing plastic capped Ebrake handles?  Its oval so i think it might fit.
Any one care to elaborate any info?
true.
Cannon fodder is my daddy.
I just might have to have one of those if we can determine fit...:-)
Steve
http://www.bluecavcustoms.com
there is a chrome version too, with a black vinyl piece on it.
true.
where did you find it at?
I'm not big I play big
Oval? The design looks pretty straight to me, unless you're talking about the actual opening part. When I refer to our "curved" brake handle, I mean the handle itself - if you start from the button and move back, it curves.
Interior FAQ -
J-Body of Michigan -
Well that curve can be shaved down for the handle to sit properly, but im curios if anyone else has tried it.
true.
the problem is under the the handle its open if you end up tapping the button at all the spring will pop off and then the ebrake handle will not work properly if there is a way you can seal the bottom section up so you cant push the button downwards then yes it should work
