I have an 03 cavalier 2 dr manual i want to redo all my interior but keep it cheap so do it myself. What is the proper way to do this, what type of paint primer and way to sand and clear coat? if anyone has any info on the way to do it or specific products to do it with please leave a post thanks alot and help is wanted
search. theres a million posts on this topic. just search for "paint interior" and you'll find all the info you need
RIP Kasey Burleson, and get well soon Chris Shelly
Nick Bautz wrote:I have an 03 cavalier 2 dr manual i want to redo all my interior but keep it cheap so do it myself. What is the proper way to do this, what type of paint primer and way to sand and clear coat? if anyone has any info on the way to do it or specific products to do it with please leave a post thanks alot and help is wanted
i didnt sand, but u gotta use a mild soap and water combo, to clean the surface, then i used adhesive promoter(a few coats), the did nice light coats of Krylon Fusion(keep it light to avoid runs), and then after its dry apply thin coats of clear coat...thats what i did and it turned of pretty good, still gotta be careful, and make sure its 100% dry before you put it back in or it can smudge and prepare for a paint smell in ur car for a bit...thats what i did, you can check out my car domain page in my registry for picks...have fun!
as for sanding i think you start with a high grit and work your way down or it could be vice versa...
^^^start with a low grit(harsher) and work your way up to a high grit(very smooth)\
ex - 80 grit is rough as hell, 2000 grit is smooth as a baby's bottom
thanks i couldnt remember which way it went
I tried painting the interior of my 180sx and I did mine with primer, wet sand, then several thin coats of color, then sevral thin coats of clear, then a wet sand, then polish, just like on the body.  It looked really nice, but remember the adhesion promotor.  I forgot the first time and it all started to chip off and it scratched really easy.
Someone should really just make a how to for painting/fiberglassing your interior.
Wide Body Progress
theres a million how-to's on here for it. it just takes a little search that no one seems to be willing to do any more
ScreamSayonaralaranoyaSmaercS wrote:SliMMaTiC (Tom Sylvester) wrote:Someone should really just make a how to for painting/fiberglassing your interior.
Interior FAQ
Yea, I know there is a prt of the FAQ about it, but as far as painting interior it doesnt go into much detail.  The first site for fiberglassing is great, with step by step instructions with pictures.  I was saying that someone should do that with interior painting.  Maybe I will make one up since I'm planning on painting my interior over winter break.
Wide Body Progress
