When I
last left off, the car looked something like this:
In the meantime, here’s what I’ve done.
note I’'m saving the goodies for last
The BC guys and the JBNW crew have had an up to date thread going… So without further adieu
July 1:
Got the trans back together. When I went to move it to clean it up some, there were bits of the input shaft bearing laying on my workbench, so get to take it apart again….
July 2:
$92 later from GM, the input bearing, seal, and rear cover seal are on order, should be here Friday or Monday. Also included are the fascia brackets.
Decided to test some of the wiring starting with the starting system. Took a few tries, but got the starter to tap (didn't try to fire it up since 1: I don't have the fuel pump feed hooked up yet, 2: no trans, and c: no down pipe installed yet).
Nothing burned up, so I guess that’s a good thing
July 3-6
Tried to troubleshoot why the fuel pump isn’t kicking on… “Last good, first bad” leads to the PCM. Either a) the PCM is toast or 2) the theft protection is kicking on. I'm banking on the latter and working on other stuff till I get the BCM wired in.
Since I’ve been working on wiring, nothing new in the picture department.
July 6: Got the new throttle cable, so I get to mark another thing off my list. Disassembled the trans in prep for the new input shaft bearing.
That’s it for now...
July 7:
Fuel pump = solved. There's a wire to the PCM labeled Ignition 0 (hot in Acc, run, crank). On the N-bodies, ACC and Lock are reversed, I think. That wire is the PCM wake up wire. Need to run a tap from that to one that is hot in run/crank on the J harness...
Just have 4 or 5 wires to go in the harness.
Also, hooked up the low-beams, need to get new sockets for the highs.
July 8:
Not really planned as an engine swap day, but ended up being one. De-stickered the car, mostly. BOOSTED hooked up the JBNW crew w/ some new banners, so I scraped all the stickers off the side windows and placed this one on the rear:
From this (old pic)
It was about time to retire the JBO sticker anyhow… it was starting to crack/peel
To this:
Hooked up the last of the wires as well (I hope). Electronically, she's ready to fire up... mechanically, no.
Need to get looming for this:
And this:
Installed the front bumper for the last time. It doesn’t quite line up 100%, but enough for my liking.
Ordered new sockets for the high beams, meanwhile soldered in the lows, so can’t put the headlights back in until I get the new sockets…
July 9
Trans is back together less the roll pin for the fifth gear fork. Stopping off at the hardware store tomorrow to go get one.
July 10
Installing the trans is a pain the rear… its definitely a 2 person job.
http://www.youtube.com/watch?v=ZUaX0f7Kumo <-- 3.68MB
I had run the first part of the theft relearn 14 min or so prior.... Working on getting the VATS disabled.
July 11
Recruited my dad to help w/ the trans, and its in. Just need to get it up into the mount brackets…
My project supervisor:
He sleeps on the roof of the car while I’m working on it.
July 12:
Lights work
So that's it for now... I'll get another post going for the next batch of updates.
And before anyone mentions anything... I know my front rotors are on backwards. Its intentional. Research has led that it will not impact performance any and in fact, may extend pad life by having them with the slots facing the rear.
Edited 1 time(s). Last edited Friday, July 13, 2007 9:48 PM
