hey im really new to this @!#$.  im new to modding in general.  im just wondering... if i want to be running 13s in 1/4 from my cav, am i gonna be putting a million dollars into mycar?
i dont care about exterior or interior cosmetics, i just want straight up performance.  so...  are 13's possible?
i have  a 2004 cav
13's are possible as long as you have about $10k
DAMN.  ok well what if im willing to....  strip unnecessary heavy @!#$ out?
and what about 14's.
Wet nitrous kit (Nx) and you are there.  Also, it's 400$ + shipping.
Gilles
2.3 Ho
yes you need a million to do it.  spend about 3k and give me the rest and i'll tell you
Shifted wrote:El Fuego ( the grounded one ) wrote:13's are possible as long as you have about $10k
Wow, what a bull@!#$ statement if I ever heard one. 13's are possible with $600, while not the safest route, it will get you there.
Wow, your suicidal.  If you wanna do it right, safely, and relaibly, its worth to spend the extra.
but its not gonna cost nearly 10ks.  you can achieve 13s safely with like 2k
[quote=ßãggéÐÇåv98  (Ûñqùðtäß£è Øñé)]but its not gonna cost nearly 10ks.  you can achieve 13s safely with like 2k
true, but you said $1,000,000, i guess that makes me the next contestant on the price is right.
no cause you're both over.
Gilles
2.3 Ho
Lets say your car runs 16s. For every second lower up to 10  seconds it is $1000, than for every second under 10 seconds it is $10,000. So from 16 to 13, about $3,000. From say 16 seconds to 8 seconds, $26,000.
damn.  well if ig et 13s ill be happy with my car.
Rob S wrote:Lets say your car runs 16s. For every second lower up to 10  seconds it is $1000, than for every second under 10 seconds it is $10,000. So from 16 to 13, about $3,000. From say 16 seconds to 8 seconds, $26,000.
I think that's a little off. I'd say every second from 16 to 13 is around $500 to do semi-safely. 13 to 10 around $1000/sec, 10 down around 10,000. Those first few seconds are pretty cheap. What you were getting at, that additional second cost MUCH more is very true.
You have a good foundation to start with (for those of you too lazy to look, he has an '04 with 5-spd).  Like these guys said above, you can get in the 13's fairly easy.
Rob
Sold 2/2/05
You can get into the 14s n/a, 13s are definatly possible.
get the eco supercharger, full exhaust, smaller pulley, a little tuning, and your there
was that hard guys?
20k for an 1/8 of a second on a 6.9 second car.
-zook- wrote:20k for an 1/8 of a second on a 6.9 second car.
no big deal lol
i wish i had the money to get mine into the 13 sec range.  good luck with it all man
75 wet shot should do it, if not pretty close..
MY 2003 SUNFIRE 15.33@88.5mph
"A N/A ecotec is not gonna give Honda's and Mitsu's that much of a run for their
money unless their blown or bottle fed.GM is still smokin crack!"
~1QWKZ24
www.streetracing.org, 08/2001
my turbo setup cost me about 2000$ CDN I made it all home made! it work fine, some little mistake again but i did a 14.6 with a broken manifold and running only 4 psi! it was my first time on a ¼ mile! you should go for a turbo! always there when you want it! no need to fill a bottle
http://cavalierdomination.monchar.com
the whsitles go whoooooo whoooooooo
bub rub~
its fo decartaion
~lil sis
boobs now with Riboflabin"
El Fuego ( the grounded one ) wrote:Shifted wrote:El Fuego ( the grounded one ) wrote:13's are possible as long as you have about $10k
$400-600 for wet nitrous system
$650 for HPTuners
$~200 for a tuner to dyno tune it
Less than fifteen hundred to put you easily into the 13 second range SAFELY!
DJTorello, LMR, El Fuego, whatever name he uses is a liar, troll, and fraud
Newbie with a Sunfire that has a different rev limit than the other hundred thousands of Js
His custom made header, AWESOME!!
His custom tubed front Sunfire from the dealer
His other personality stole his identity
Fastest 01 Kia in 97, check out his great pics and comments as well
